We are going to install geothermal cooling/heating in one of our sheds and I did some research on it and i just wanted to check and see if anyone can confirm or deny the info i found? First the shed is 24 x 30, it's has a concrete floor, it's all metal except it sits on wood which bolts on the floor and it's not insulated yet. We have a backhoe so that should save us a lot of money there. The info i found said there are 2 different pipes you can use, both plastic, i forget the technical names but i'll be able to find it again. But i didn't find what size pipe to use. another site said 3/4 inch and another one said 3 inch, but i don't know what size building they where using it on. It also said you need at least 500 feet of pipe. First 6 foot deep then loop it back 3 feet deep. We will most likely go the hick route and use a radiator for a super duty and maybe use a box fan or something ghetto like that and some type of drain for the condensation. (haven't figured that out yet) My dad found some small pump to move the water that's supposed to use very little power. And it said you're supposed to use a special antifreeze but my dad figured we could just use water because the pipe is deep enough to never freeze and what little would be above ground will most likely be moving. (I would prefer to use the antifreeze) also i would rather do things overkill then to size everything just right for a 24 x 30 building. any thoughts? and i know my description on how to do it isn't impressive by any means but it should work for me.
