- May 18, 2008
- 92 & 83 project
- Automatic
on the 84 buggy, i am having charging issues. to eliminate the system I did buy a new alt, even after changing with 3 others i have in the shop. (all 4) have same issues. wanted to eliminate so bought a new one to be sure.
now i get 10 volts to 11 volts with the truck running with the lights on and the heater in full. the battery didn't charge from the maiden run a while back, and i have been just using trickle charges to keep the bat up in charge when it is parked. I have not died yet with the truck how ever, have not driven it more than 10 miles per trip keeping them short in case the bat does die.
i have rewired the alt directly to the regulator with new wires. ground, and field and stator. the wire harness is a bit chopped from PO i also eliminated the (brain box, and electric crap).
I also want to eliminate the AMP meter in the dash. however, can not figure what wires to cut from the wire harness.
can take pics if needed. want to know how to test the regulator properly, or if i have it proper.
cheers thanks
cheers thanks
