got a custom grind from comp cams in san diego.. (lived nearby at the time).. its got a choppy idle, it does have a more top end, increased fuel usage (get about 8 - 10 mpg), doesnt work very well as of date cuz i told i would be using a 360 4 bbl on the offy manifold (which i have been unable to get for under $500) and 4.56 gearing on a rebuilt motor .40 over. get some hiccups when a slow down from speed and loss of power brakes from the loss of vaccum (sure i have a leak somewhere too). i mainly use for play (open desert), or trips to the dump. be very specific if u get a cutom grind.
during ur rebuild keep it stock untill you complete your other mods, gearing would be my first $$ spent, can regain alot of go from there. in my experiance, i should have saved the cam swap until after i got the offy (buyer sold to someone else on my drive to see him in pheonix)
yea i know, bad wheel and gear combo, saving up for dana 44 & 9in swap..
engine info:
.30 over, knifed edged crank, msd, holley 320 cfm carb, aerostar headers, 4 inch lift, fiberglass fenders, 3 core AL rad, turbo 4 oil cooler, 33 on 3.45 gearing (crap)
