any measurements for fender flare holes
94 lngbd
Lakewood,Wa
I have a 94 Ranger that i'm up grading to have the 2003 front end. I have the fenders & also a 2003 bed to replace damaged 94 bed. I just recently got a complete set of EDGE fender flares & need to know if there's any dimensions for drilling the holes into fenders & bed for the fender flares to mount into?
Thanks in advance for any info.
WOW, you mean that after 29 people looking at this no one has info about the locations of factory holes on bed & front fenders for factory flares!!
No. We all have the information....it's just a secret.
im referring to the holes that the fender flares clips snap into on the front fenders & the wheel openings on the bed
PITA… I know, the holes are what is stopping me from putting the flares on my new bed.
It would be nice if there was a templet, tape it on mark the holes and drill but I have not found anything.
My thought is this, in a few weeks I will tape on my flares, get the position I want, both of them.
Mark the top of the flare with a thin edged, removable marking pencil and use that line to determine the position of the holes.
Both sides could be a little off from each other because who will see both at the same time but I think they will work OK.
next thing is new clips, right now Ford is the only supplier I can find, hopping that "Clips and Fasteners" will have something.
Drilling the first hole will be the worst part of it, the rest will some easy.
Luck.ltr,
My bad as I forgot until today when I got my 2003 fenders out of storage that they already have the fender flare holes in them.
I will measure the distance that they are from each other & from the fender lip & post the info when I get that done ,but I still need the dimensions for the bed sides.
Called the dealer & asked if theres such a template & he said no but to use a big enough pc of cardboard & press fender flare onto cardboard to make indents from the clips & mark the edges of the flares & then I would have a template.
I may try that or put some wet paint on end of each clip & then set flare up against bed
Im bringing this thread back because I'd like to add the rear fender flares to my current bed that does not have any. Please anything helps, a template or if there's another thread elsewhere
Featured Ranger Based Vehicle
