OilPatch197
- Sep 23, 2007
- Age
- 96
- Automatic
1996 Suzuki Quad runner 2WD.
The rear axle bearings are wiggling, I need to get in there they probably need replaced. It is just like a 2WD cars front bearings, you remove the spindle nut and the hub slides off with bearings....
I tried a 4 ft cheater bar, soaking the spindle nuts in Penetrol 90.
These beefy spindle nuts are NOT BUDGING. I think I will have to cut off the spindle nuts.
What is the best way of doing this? Do I use a drill and drill out the nut and use a chisel to pop it off? What is the best way of doing this without F'ing the spindle threads?
