Hotrodlincoln
- Jan 7, 2008
- Automatic
Trying to help my neighbor with an airbag light on his 2003 Taurus.
It started out as a code 36, which I've come to understand can be for either the passenger OR drivers side airbag circuit. This car doesn't have side airbags, it has the yellow jumper plugs under the seats. I checked the wiring as best as I could without removing the seats and tried swapping the jumpers for some from a junkyard car with no change. I tracked down the SRS control module under the dash and was going to check resistance on the side airbag wires but I don't have a pin small enough to fit into the connectors. But after plugging it all back in and connecting the battery, the light comes on, with a new code. It's now flashing a code 37. I counted it 4 times just to be sure.
It took some digging but I did find some info, and I've found it could mean any one of 4 things for the passengers side airbag.
Can I scan this with an OBD2 scan tool and get a DTC to match up so I'll know what problem to chase? Or does it have to go to Ford to be scanned? Also could the previous code still be present but just isn't showing up?
I'd love to find a factory shop manual for this thing online but no such luck yet.
