- Dec 3, 2016
- riverview, fl
- 2.9 V6
- Automatic
- Total Lift
- none but it is a convertible
- Tire Size
- stock
i have a '94 motor that i believe is a 2.3. someone said there may be differences where the crank sensor bolts on from what a '95 2.3 has. apparently ford changed the voltage of the sensors between '94 and '95. i want to overhaul the '94 to make a long block and swap stuff over when i pull my long suffering 95 with 400k on it. am i setting myself up for major headaches? and where on the block will i find numbers to ID it?
