- Feb 5, 2020
- California
- 2.9 V6
- Automatic
So I recently acquired a 2004 ranger that had a bad 4.0 v6 in it. I pulled that engine out and dropped a 2009 2.3 4cylinder in it. Which meant I had to change the entire wire harness. At some point in time while I was doing this swap a buddy of mine pulled the ignition switch out of the column without my knowledge and now it’s nowhere to be found along with the key. So after doing all of this as soon as I hook the battery up the truck started beeping. So I look at the dash and all the lights are on and the anti-theft light is flashing(mind you I haven’t even put the key in at this point). When I realize that the ignition had been pulled and not being able to find it I stuck a screwdriver in the ignition and tried to turn I over and I get absolutely nothing. If anybody has an thoughts on what I need to do it would be appreciated. Thank you
