ben416
- Sep 19, 2010
I have been noticing a loss of power in my 2001 Ranger 4.0 over the last few weeks. I had also been hearing a buzzing noise on and off which I thought sounded like electrical buzzing from around my coil pack but it turns out it was the hose under it. When I wiggled it, the noise went away on and off as I moved it. The noise also fades out like vacuum when you shut off the engine after the revs drop to 0. However I also noticed a hissing coming from under the plastic throttle body cover recently too. I'm assuming either spot could be the cause of my power loss. I can't even spin the tires easily in dirt in 2nd gear and the A/C / Defroster kills my power even worse.
I'm going to a friends house with a garage tomorrow to look into the hissing noise under the plastic cover. I assume that may just be a loose hose. However the leak causing the buzzing noise puzzles me. I'm not sure what the hose goes to or even what part I would need to replace. It goes behind the engine and I think maybe around to the intake on the front.
Here is a picture of the L shaped joint the hose is connected to that the buzzing is coming from. It seems to be a little lose from the engine.
Any ideas on what this is would be appreciated. I tried looking up vacuum diagrams but I couldn't relate them to my problem as I can't see where they match up to my engine bay.
Thanks
Edit: FYI plugs have been changed, air filter is OK and the MAF has been cleaned recently.
Thanks
