harriw
Hey guys (and gals),
Just noticed shift rail plugs are leaking, making a mess. I've read through all I can find on the subject, but have a few quick q's:
1. What have people used to clean up the area before RTVing in new plugs? Brake cleaner? Carb cleaner? Anything I should avoid, in case some of it drips into the transmission? Just spray it down, and use a rag to clean out the three holes?
2. Any tips on where to find replacement rubber plugs? I hear the dealers want $6 each or so... Do the chain stores have them? What size should they be?
3. The fun part - any great tips on how to get at them? I had a really tough time finding them from underneath, so I'm thinking from the top (Remove shifter) is my best bet. I just popped it off tonight and found the plugs (yeah, they're loose, moving around easily in their old RTV - really hope that's the source of the leak), but there's not much finger room with that bolted-on plate there. I can get them out no problem, but I'm not sure I can maneuver the new ones back in, particularly with them covered in RTV. Can I cut out a section of the plate with a dremel to make more room? I know the plate unbolts, but I'd need to tear up the carpet to do that, right?
How fast does the fluid drain from those holes? I've only had the truck a month - should I be worried about fluid level? I was going to do a drain and re-fill anyway, but was hoping to wait until next month (this month's "fix the truck" budget is pretty much spent already - new thermostat, coolant flush and re-fill, fuel filter, air filter, MAF cleaner, rear diff. fluid change, etc., hoping to do it all this weekend).
Thanks a lot!
-Bill
Thanks a lot!
-Bill
