junkfixr
the vacuum switch/solenoid on the firewall (87 ranger) ... does it send info to the EEC IV ? It has a top & bottom barbed fitting & since the former owner monkey'd with the hoses, I'm not sure how they are routed or what they're supposed to go to or from.
Autozone doesn't show a good diagram for this model & was wondering if anyone had a pic or description of how it works ? It's gotta K&N air filter so the box has been ripped out & manifold vacuum port is plugged off. Wires are still hooked to the solenoid but no hoses there either.
Since I've got white smoke & "flooded" symptoms at cold start, think I'll begin with a compression test to eliminate a cracked head, & then look at electronics & fuel problems.
