lorenambrose
I am literally having the EXACT issue Blackedge03 was having with his 2003 Edge 3.0l.
I have a rough idle. Feels like a misfire, but I am left scratching by head. PLEASE HELP.
Here is the data and work done so far:
2003 Ford Ranger Edge 3.0l FFV 2WD with 5 speed AUTO.
1. Recent compression check numbers:
cyl1 161
cyl2 156
cyl3 160
cyl4 160
cyl5 146
cyl6 165
2. Vacuum check:
18" and steady
3. Fuel Pressure check:
a. ~40psi withe key on engine off
b. 60psi with engine running
c. Leak down test:
- Fuel psi drops from 60 to 50 when engine is shut off and holds steady
- Pressure drops ~12 psi in 30 minutes
4. Checked the PIDs with my scanner and all are within factory limits. Specifically checked the following:
ALL CHECKED WITH THE ENGINE AT OPERATING TEMP
a. TPS% = 17.8
b. LOAD = 21
c. All Fuel trims = within specs
d. MAF = ~4.9
e. Spark Advance = 18 deg
f. CTS = 193 deg
g. O2 sensors = within specs
I have changed or had the dealer change the following:
1. Coil Pack
2. Plug wires = Autolite premium
3. Plugs = Autolite Extreme Performance XP104 gapped to .045"
4. Upper Intake Gaskets
5. Heads and Head Gaskets due to an overheated engine.
6. TPS (throttle position sensor)
7. IAC (idle air control) valve
8. Fuel Filter
I have performed the following recent maintenance:
1. Oil and filter = Valvoline Maxlife 5W-30 w/ motorcraft filter
2. Seafoam through the brake booster hose twice in the last month
3. 3 tanks of Shell 87 with Techron or Gumout w/ Regain fuel system cleaner
4. Winns fuel system service = same as seafoaming in reality
5. Cleaned MAF with CRC MAF cleaner
6. Sent oil sample from last oil change to Blackstone for analysis. Awaiting report.
Ford Dealer performed Power Balance check and found nothing. Mode 6 data revealed a misfire on cyl 5 & 2 but never threw a code or CEL. Mechanic found no reason for the misfires.
cyl1 161
cyl2 156
cyl3 160
cyl4 160
cyl5 146
cyl6 165
2. Vacuum check:
18" and steady
c. Leak down test:
a. TPS% = 17.8
b. LOAD = 21
d. MAF = ~4.9
f. CTS = 193 deg
1. Coil Pack
8. Fuel Filter
