Another Duraspark convert...
Cool hopefully the shaft will loosen up over time. I had a carb that would stick only when the engine was running I think the vacuum pulled the shaft down in the center causing it to bind. It was a carb I bought off ebay and someone had pulled the butterflys off the shaft on a rebuild I am guessing and didnt get then lined up proper when he put it back together. I could tell by the screws werent the same as a stock carb hex screws.
