Hello All,
I'm new to this site, but have owned my '85 Ranger for about 14 years. The whole time Ive had it I have always had trouble getting it to pass emissions. So for about the past 6 years it has just sat on the side of the house and has been ignored until it became exempt.
When I fired it up a month ago, it ran like a$$...but I expected that. I bought a rebuild kit for the carb since I had noticed a fuel leak from the accelerator pump and did the whole carb fresh again. Still didn't help it run any better, but cured the leak. It would'nt idle at all without feathering the pedal. I ended up having to turn the idle mixture screws out about 5 to 6 turns to make it idle. But the Fumes...( Oh Your God !!! )
Looked around online for info and help to make it run like I remember it used to, and this site seems to be the place that pops up the most.
So reading thru the threads in the 2.8 section I found about the duraspark conversion...hmmm...why not, couldn't run any worse. After 2 weeks of reading all that I could find out about this mod, all the help, issues, technicalities and problems involved, I decided to jump in and start clearing the trash from the engine bay.
I bought all the parts new, except the carb. Couldn't find one that was compatible, and the schmuck at O'Reilly's kept talking about the electronics that would come with the replacment '79 Pinto carb. Couldn't seem to get him to understand that I didn't want all the feedback controls..that was the purpose of this conversion. So anyway decided for now to keep my stock '85 carb and make a metering block. ( At least for now. )
Then the fun began....cutting wires ... bending metal ... drilling holes ... rearranging components ... Got it running and the throttle response felt a bit spunkier. Got it idling, altho very rich and while looking up info to help set the mixture better and set the timing, the engine stalled...I kept digging thru my manual looking for info, then called it a night. Turned the key off and went inside.
The next day I tried to start it and no spark...WTF? I thought maybe my 14 year old Accel Super coil failed so replaced it with an MSD Blaster 2, still no spark. Dig thru the site some more and "now" i find out, "Don't leave the key in the run position for extended periods.." So I replaced the module with a new one and we are happy to be running again. Then I find a fuel leak from the fuel pump....switched that out with an electric fuel pump ( cause I didn't want to dig down in that greasy nasty looking location to replace the mech pump )
All in all the engine bay looks much roomier, truck runs much better now But not great...I still have alot of work to do.
Here is where I stand right now...
I still have an erratic idle after it warms up...surges from 900-1400 rpms. ( But at least it stays idleing for the most part. )
I still need to make a metering block..( don't know if that will help the surging idle. )
The idle mixture screws are about 2 turns out right now..( much bettter than the previous 6 turns. )
I know I need the valve seals. ( but down the road a bit. )
I need to adjust the valve lash.
All in all....much happier with the look and feel after this conversion.
Thanks to everybody involved with posting info to this site. It is greatly appreciated.
