another 7.5 rearend question
marcuspur
so my spider gears are bad and i want to change out the chunk if i fine another chunk out of a 7.5 and its the wrong ratio can i just put my ring gear on it
No problem. Just make sure its a 7.5
it just sounds like u have a excuse to order a mini spool for ur truck:headbang:
I'd just drop a lock rite into it. It's a spider gear replacement lunchbox locker.
You can find them for roughly $300 probably less if you look hard enough.
Much easier than having to reset your pinion and ring gear.
Pick n Pull or junk yard!
I just changed my entire rear end for a posi with 4.10's for under $100
