fireguy12117
I replaced the ball joints, rad. arm bushings, put newer stock springs in, new shocks, and got an alignment. truck does steer better, tracks better, and rides better over all, but...there is this dang annoying rattle that for the life of me i cant make sense of. when i am braking over bumps i hear a clunking going on and it sounds like both sides of the truck. could the sway bar assembly be causing a pretty audible clunk when rolling over bumps? i know its worn out, so that's why i suspect it. just wondering if peoples experience has been that the sway bar can do this before i bother with it. Also, anything else i should be thinking about? i cant really think of anything else if we assume that all that got replaced is solid. i will double check- again...all those components.
oh! 1.5" coil spacers got put in too...good ole welded washer style.
