tx_pwp5
- Dec 11, 2015
- Austin, TX
- 2.9 V6
- Automatic
- Total Lift
- 4 inches
- Tire Size
- 31x10.50
- My credo
- More auto shenanagans on instagram @waterloocustomworks
I just put a 4in lift on my truck (87 supercab 4x4 built 7/87). The helper springs weren't enough so I'm adding explorer leafs to get the height right.
My question is this:
I've heard from multiple sources that after 4 inches or so of lift in the rear, the 1st gen two piece drive shafts can get some vibration in them, and the "easiest" way to fix this is to swap out a one piece shaft from a newer ranger. This involves some clearancing and of course, a trip to the yard.
Why couldn't you just switch out the stock two inch blocks with a 2in angled block to adjust the pinion angle? Wouldn't that correct the driveshaft angle and get rid of the vibration?
I'm probably missing something so if anyone has tried this, please let me know. Maybe the vibration is at the front of the shaft and that won't change with blocks, idk.
Thanks in advance.
Thanks in advance.
