Andres629's still at it! '87 BII this time!
haha, awesome.
andres. you need to get a D35 in there, i took the d28 out of my 86 ranger frame in change for a d35 tonight, and she doesnt even have a cab, let alone me using it!
I have one, with 4.56's and a locker! Just need to get the rear driveline figured out, but in the meantime I can still use 4x4. :D
I kind of need the rear ratio to match the front in order to use 4x4... and that's my main priority on weekends, the use of 4x4!
ok, i was thinking you already had the rear gears just ready to put in lol
I have the rear gears setup and in the Expo 8.8, but I need to set my pinion angle and get the rear driveshaft figured.
ok cool. 8.8 shaft isnt the same as the one for the 7.5?
Nope, the one I have is the baby u-joints. Different pattern on the flange.
Just drill new holes in the 8.8. Thats what I did.
i know its an older pic but i just had to point out the tester timmies cup lol
Tim's FTW.
Hey Andres, I may be a pavement pounder but you're the one that's repping FWD.
Am not, Mike! Was repping FWD last week for two days when I busted a u-joint on the rear shaft, but fixed that. I'm still rockin' the D28/7.5 combo 'til I can get my M5/D35/8.8 in all in one shot, 'cause I can't go one weekend without 4WD. lol
Disciplerocks, I'm going to be running a manual BW1354 with the 8.8, and I want to upgrade to full-size u-joints rather than the baby ones. Going to run a 1st gen Expo front shaft on the rear to get the double-cardan and bigger joints.
To Kris, that cupholder sees more Timmies cups than anything! Although, it fits a Monster can perfectly without spilling, a regular sized pop can won't come out less'n I'm upside down, and a Timmies cup all the way up to XL fit snug as a bug in a rug. :headbang:
So based on what you are saying if I put the 8.8 from my 92 to replace the 7.5 I'll have to change out the driveshaft too?
