Hoosierman
New grounds from battery to chassis to block. Battery to body. Block to firewall. In the process, I discovered that the EVR's connector was thoroughly rusted through and the connector pigtail was so corroded from this that it is compromised. Parts are cheap so I have a new EVR and pigtail I'll be installing. Not entirely sure if this is the cause of no-start but I know it isn't helping.
Both the old and remanned starter motors were tested, and confirmed to be good. I don't know if it's the "best" way to test it, but the relay to motor cable was given a continuity test with my voltmeter and gave me a solid 0.00 ohms.
I've poured through what JoshT had to say above to see what I can trace. Bit by bit of course, I have been winterizing things so haven't been too involved with the BII.
