steevn
- Aug 24, 2010
Hey guys, most the guages in my truck stopped working so I replaced them with some auto meter stuff. After putting in the new guages the truck no longer charged. Thats when I discovered the amp light circuit seen here
http://www.therangerstation.com/tech_library/EDiagrams/files/Diagram_charging_1991_2.JPG
Its a 510 ohm resistor in paralell with a light, the total resistance is about 95 ohms. So how much resistance does this circuit need? What does the amp light do? Will I burn out the regulator if I just twist the wires together?
