Hey all.....been a while!
So my amp keeps blowing fuses. I have two Kicker IX402 amps, one for the subs, one for the doors. The fuse on the sub amp keeps blowing, has only been doing so for the last couple months. It's not blowing the in line fuse, just the fuse on the amp. It was doing it nearly every i used the truck. I would replace the fuse and listen, next time i use the truck fuse is done. Last month i replaced the battery because the factory original finally died (after 9 years and 114,000 miles). When I did this, the fuse stopped blowing and everything seemed fine. Last week my MAF was throwing check engine codes, so I cleaned it.....disconnected the battery while doing so. Ever since..........every time i use the truck the fuse blows again. I checked the battery terminals and made sure everything was tight. I was told to check the volts on the battery, then check the volts on the battery when the truck is running to see if maybe the alternator is dying.
Anyone have any ideas? this is driving me crazy having no bass!
