- Nov 27, 2008
- central IL
- State - Country
- IL - USA
- Drive
- 2WD
- Automatic
- Total Lift
- 6+3
- Tire Size
- 33/12.50/15
I have a 94 ranger with a 2.3. I have an annoying problem with amp gauge jumping. It only does it sometimes, mostly when idling. I checked the wires going to the battery and they are tight and look clean.wires are plugged in and tight on alternator. New battery and alternator. I am thinking about replacing the battery cables. I tightened up the wires on the battery and it quit doing it as bad. I haven't got a chance to do any checking but the idle is rough and it ran much better after tightening the battery cables also? I hate to start replacing stuff with out someway to check it. I have a code reader but no codes come up. I was wondering also about the ground wires being bad or loose? I really need some idea what and how to check for the problem. I have never changed out the battery cables before but have a couple but am not sure how much trouble it will be. I trimed the ends on the old ones because they were corroaded then put new ends on.any help out there?
