- Feb 14, 2018
- Seattle, WA
- 4.0 V6
- Automatic
- Total Lift
- 2"
I bought my 2011 4x4 Sport a few years back as a used vehicle from Canada. This thing has NOT been maintained properly, so one of the first things I noticed is the spare tire hoist didn't work. I bought a new one from Ford, and had to cut the old hoist's cable pin to remove the spare and install the new hoist.
I am TRULY unimpressed with the design - the tip of the jack shaft does not stay in the little molded niche in the plastic "funnel", but spins out under any kind of strain. My 1999 never had this problem, and had the same design, so maybe the tip of the jack shaft is buggered, but I'm really hoping someone has come up with a better mousetrap.
My current solution is a 1/2" 12pt 3/8" drive socket hammered onto the lift shaft, and a 1/2"F to 3/8"M socket adapter snapped into that, and all installed as normal. I've taken one of the jack shafts, and squared all the edges on the female end, so a 16mm 12pt socket will fit on it. I then install that at one end of the jack shaft and leave the shaft that has the curved tip completely off. This whole shaft gets inserted backwards (the male end of the shaft fits perfectly into the 1/2"F adapter), and a 3/8" ratchet wrench hooks to the 16mm socket, and Robert's-Your-Mother's-Brother!
But it's ghetto, and there just HAS to be a better solution.
Any help is appreciated!
