compleckz
long story short, i have a twisted/snapped piece of the driver side shaft stuck in my lockright.. i couldn't pull it out with a strong magnet, or bang it out from the other side, because where it twisted and snapped, it is wedged between the bearing and the side gear of the lockright.
i pulled the diff. tonight, and planned to remove the lockright piece by piece to get the broken chunk out. but apparently when i had the diff. regeared, the shop jammed it in there pretty tight (old school joint), before (stock) i could yank it out by hand with very little persuasion.
i've read some redneck prybar/long bolt in the ring gear/rag in the pinion teeth tricks.. but the first two make me nervous seeing as this is an aluminum housing. i dont know anyone with a case spreader, nor do i want to buy one. im not completely opposed to making a simple one, but im looking for other options.
thanks
also i'll post pics of my axle carnage later.. the entire drivers side was a mess.
thanks
