Alt/PS bracket questions
RebuildRanger
Earth
Alright Im having issues with figuring out the right brackets to use and power steering as well
Im running a vbelt setup and im trying to find brackets ive called summit and the only thing they have for the power steering bracket with a driver side outlet on the water pump is a bracket that requires a custom pump.
heres the link for the pump
http://www.summitracing.com/parts/MCH-P330/
the bracket for ps
http://www.summitracing.com/search/?keyword=mch30356 &dds=1
and alt bracket
http://www.summitracing.com/search/?keyword=mch30355 &dds=1
are there any other options for brackets that run a v-belt style with driver side outlet on the water pump?
Also does the pump Im going to use (the summit tech said the pump is for 73-76 mustangs) be able to work with my steering box. I dont think the lines would be all that different.
Any help would be appreciated as these are the last parts that I have to order, Im almost there!
So what happened with this? I'm looking into the same setup very soon...
