pSycHOarsOnisT
So i tried the bent pin fog light mod and it wasnt working, so i tried jumpering some contacts and ended up blowing a fuse. After replacing the fuse i had no fog lights or dash lights. All fuses were ok and relays seemed to be working. I replaced the headlight switch which i got to work by flipping the contacts and doubling the springs for them. So now my fog lights and dash lights work but the light that indicates cruise control is on only comes on when all the dash lights are on. ( it used to come on anytime) also my headlights do not turn off when the truck is running, it is not drls (as far as i know)because the brightness does not change when i set the switch to headlights on. On top of that, my high beams now only work when i use the "flash" by pulling the lever towards me but not when i push it forward and it clicks.
Any help is greatly appreciated
