you more than likely will need new camber eccentrics. i really don't see how it would stay in spec with even 1/2 in of lift.
yep, the adjustable eccentric bushings(bolts) correct the camber & the caster on a T.I.B.
In stock form there is no adjustment for camber/caster, you will need the upper eccentric bolts for an alignment to be performed if it requires more than just a simple toe adjustment.
it depends on what bushings the truck got from the factory. most trucks didnt roll off the line with a zero degree bushing, most needed an offset bushing to align it. granted his stock bushings arent offset enough to align it after a 2" lift.
