scottg
took 2 days doing it myself, working from 10-5 with plenty of stops to the store and work. Had to use the shop's torch on the big center bolts, ending up replacing both sides
So far I only have the front, haven't decided on what to do to rear (currently just flipped shackles). Installed Used DJM Beams and OEM splash coils. Currently the fronts are sitting on 235/55R17, but are getting swapped to newer 235/50R17 after the alignment. I have adjustable camber/caster bushings in it, so its going to be a fun drive to the shop, not even close to being straight!
