Alignment Parts.
Dtotheevin
Firefighter
EMT / Paramedic
USA
Hey everyone, I have a 2004 Ford Ranger 2wd w/ manual transmission. I recently had the front end suspension rebuilt and took it in for an alignment and the company said they couldn't fully complete the alignment due to missing parts for the upper control arms as noted in the photo attached. Which only has a new washer part noted. I read an article that all Rangers prior to 2004 needs new parts ie wash and nuts. I was just needing guidance my guys. Any help would be appreciated, I apologize for the picture quality. The part noted in picture is "W705040-S900".
These work on both my 2000 and 2005.
In your pic on the right side you can see the top edge of the camber plate protruding above the frame bracket.
That is rotated to move the bolt in or out. There is a slot under the bolts head that allows in/out movement.
Your bolt looks like it would limit the amount of adjustment if it is keyed to the camber plate.
A pic of the other end of that bolt would be helpful.
2001 Ford Ranger Camber Alignment Kit | NAPA Auto Parts (napaonline.com)
