airbag light and 4 hi and 4 lo lights flashing
rangertoy
Firefighter
EMT / Paramedic
ASE Certified Tech
Bay Springs, MS
6?
This started when I put my truck back together after changing the heater core. The airbag light is flashing a 2/7 pattern, which is the indicator light for the passenger side airbag cut off switch. The 4wd lights are flashing 6 times then stop, until I try to engage 4x4. The rear running lights and rear turn signals are not working either. I have gone through the process of looking for blown fuses, plugs I may have missed when putting the dash back together and have tested the little light in the passenger side airbag cutoff switch. when I tested the light with jumper wires it lights up. I really don't what to do next, any help is appreciated. By the way my truck is a 99 ranger 3.0 auto.:icon_cheers:
99 is probably the same as 2000, for which I have the EVTM, at your disposal.
PM me your e-mail address and I will send you a bunch of schematics tomorrow. Maybe tonight if they are in my hotmail. If I'm not real busy, I'll try to figure what's common with all those symptoms. Either way, I'll send schematics to your e-mail address.
Welcome to The Ranger Station!
PM sent thanks
Got it figured out. It was a loose connection for the in cab fuse panel. Thank you for all the help Earl!
