kenwheeler
I dropped the trans to replace the clutch. New slave while it was apart. Couldn't seem to get any clutch pedal. Took the master out and bench bled it. No air bubbles in the reservoir and the rod couldn't be pushed in. Still too much air. Dropped the trans and replaced the slave again. I'm still getting to much air. I hook a hose up to the bleeder valve and put it into a jar. If I hold up the bleeder hose connection, loosening the bleeder valve further, I get lots and lots of air bubbles in the jar. Is it possible that I'm opening the bleeder too much and the air is coming from around the bleeder valve? I've gone through 3 big bottles of brake fluid. When will the air stop?
