my 2003 Ranger FX4 has air shocks in the rear. Installed by its last owner. Im guessing by all the towing exuiptment he installed on it he did a significant amount of towing with it. the other day was the first time i drove it on a road bad enugh that i could tell somthing was not right with my shocks. today i found the a leak in my air line between the "T" joint and the frivers side shock. we cut out the bad section and re atached it. then put air to it. the drivers side started lifting up, but the pasangers side did not, and wereever the leak was caused the air we put in to quickly drain. this is my first rig with air shocks. so hear is my question. a friend of mine told me that if i had driven it like that with no air in the shocks, that the shocks were destroyed, and would need replacing. is that true? and if they do need replacing, should i look into new air shocks, or go back to traditional shocks? i dont plan on towing much. maybe once a year, but when i do it will be towing a bronco 2 on a car trailer. also i want to jack up the rear end some, and i know air shocks can do that, but so can helper springs or add a leafs.
