Air flow will not change from dash vents to defrost
SmokeEater829
New Orleans, LA
1989 Bronco II. 2.9L 5 speed 4x4.
A/C works and blows cold. Heater works and gets hot. Only problem is, the air only comes out of the dash vents. I cannot get the the air to come out of the floor, or defrost/winshield vents. What do I need to check? Not concerned with the floor vents, but I need the defroster to work. Frozen windshield in the morning sucks!
if I remember correctly, check the vacuum source. That is what changes the position of the blend door. Then check the blend door linkage behind the glove box.
I'll check on the blend door. I noticed that the slide switch is kinda hard to move so I guess I need to check on that too.
Blend door is working fine. Must be a vacuum problem. Waiting for my EVTM to get here. Hopefully that'll help me out!
