#1. Throw the hose w/out the gauge away, or put a gauge on it.
#2. Make sure it is not something simple like a blown fuse or fusible link, check the relays, fan clutch, compressor clutch etc.
#3. If all the other electrics check out, then ideally get a manifold gauge set, it will cost you in the neighborhood of 90 bucks. If money is a problem, get a refill kit that has a gauge on it.
#4. your A/C pressure on the low side (and high side too) will depend on the outside air temp, the relative humidity and how plugged up your condenser is.
*note, if someone has the temperature/humidity/pressure charts... please post them. I do not have access to them at this point, I think I have them at home, but it would take me forever to find them.*
#5. hook up your gauge set to both high and low side, open the valves at the hookup points to allow the system to reach the gauges, but do not open the valves on the manifold itself or the freon can. On the refill kit hook it up to your low side and do not open the valve to the freon can just yet. Start the truck and put it on max a/c blower on high. look at your gauge on the low side of the manifold gauge or the single gauge on the refill kit.
#6. your low side (if you have the manifold gauge set) should read around 30 psi to 45 psi depending on outside temp and humidity. IF it is cold outside, it will read lower. another point to mention, it needs to be at least 70 degrees outside or in the garage where you are doing this....
#7. If you have a refill kit, the gauge should read 30 to 45 psi depending on temp.
#8. If the compressor does not even kick in, and you have extremely low readings on the gauges, you are probably out of freon. If the system is completely empty, no pressure readings at all, you need to evacuate the system to a -30 psi and hold that for a few hours to get the moisture out. If you fail to do this, ice will form inside your a/c system and this is not good...you can trash the compressor. another note, if the system is completely empty, find the leak and fix it. Replace the receiver/dryer while you are at it. this is the opportune time, you do not have to worry about venting the freon (illegal anyways)
#9. If you do have some pressure, but the compressor is not kicking in, open the valve to the freon can now (with the truck running of course) and open the valve on the low side to the manifold if using the manifold gauge set. fill the a/c system until you get the 30 - 45 psi on the low side. It should take no more than 2 12oz cans of freon, and probably less! (again if someone knows the exact capacity, chime in..) You do not want to overcharge the system! if you have put a can and a half in and nothing has changed, stop, you got another problem that needs to be addressed.
#10. after you get the proper charge, close all the valves and carefully disconnect the hoses. you are done.
#11. other problems you might have...If the low side pressure goes way up and the high side pressure is fairly low, you might have a bad expansion valve. requires recovery of the freon and taking the system apart to replace. This is one of the times where the full manifold gauge set is helpfull. the refill kit will not help much in this case as there is not gauge on the high side.
Hope this helps, and for the a/c techs on the board this is all from memory, so if I have forgotten something, please feel free to chime in.
AJ
