DangerRanger2.9
- Sep 24, 2010
Hello all,
I am having problems with my 86 2.9L. I have only owned this truck for a few weeks, so i am still getting to know it (first ranger, first OBD I vehicle). The truck has idled high since i got it, it idles the normal 1100-1200 on cold start up, then when the engine comes up to temp it bumps up to 1300-1500 idle, and stays there. The TPS is at .86 volts at idle, which i understand is a little low, but within range? The throtle body is clean, both sides of butterfly. So i checked my Idle Air Bypass Valve, at idle i unplug it and nothing changes what so ever. Then cleaned IABV, no change. Then replace IABV, no change. Still can unplug at idle and does nothing. Check voltage at IABV, 13.2 constant volts at idle. From what i gather, it should be a constantly flucuating 0-12 volts? What would couse the constant 13.2 volts? I can lower my TPS to .70 volts, and she idles at 800 or so RPM, much lower volts and she just dies. sorry for the long post, and thank you for your inpute. P.S., no i havnt had a chance to check codes. And yes i disconected battery to reset system everytime i did some thing. Thank you.
