Optimaldave
I am fairly fimilar with what my '88 had, but that vacuum routing seems awfully fishy..
Like the carbon canister ran to a vacuum nipple under the throttle body. And the ""B" goes to the other side.." went to E. But what goes to B? The MAP line you have might be FPR. Does you have an auto or manual? Cruise, etc?
Only way to "fix" it is to positively identify what is what, and cap off any additional taps. A vacuum tap is a vacuum tap, not sure why you have a vacuum line on one side of the plenum going to the other, it's the same vacuum source..
It is a 5speed, with cruise control, power nothing, had A/C but it has been removed...
I agree that one of the two "B"s should be run to "E"
I have seen from other threads on this forum that it would appear the "B" on the passenger side of the plennum goes to "E" on the airbox.
but it then makes me wonder what should be drawing from the now open "B" nipple...
Granted when I pull the airbox there won't be anything to draw from so I just have to worry about if the other lines are correct
Cheers
