Air bag sensors.
fourwheelford
washington state
Hey everyone I didn't know where to post this so please move it if its wrong.
I need to know where the airbag sensors are on a 2000 3.0 4x4 and the basic workings of the drivers side airbag. I need to remove it to check some things out my airbag light is on, I know the procedure to get it out but I don't know how it all functions and what part may be bad that caused my airbag light to come on and cruise control not to work. Both airbags are in the vehicle. Any info would be great I want to trade it in but with the light on they will rape me even worse on the trade thanks in advance for any info. The light is flashing a 32.
Ok after some research im pointing to the clock spring I still don't know what im doing in the steering wheel,I know to unhook the negative on the battery for like an hour and turn the lights on before touching it.
Disable air bag:
Ignition off, unhook battery cables (both) for two minutes. Side air bags will have a disable switch. I've done this procedure a few times and removed the steering wheel bag with no problems. The backup power supply does not hold a charge very long.
The system works with sensors that send their signal back to the electronic diagnostic monitor (EDM) if there is sufficient G force at impact, which inflates the air bags. The EDM supplies the power to the system and checks the system when you turn the vehicle on. If there is a problem the light will stay on or flash. You are right that a clock spring or coil assembly in the steering wheel transmits the signal to the EDM, but I don't think you should mess with the system yourself as your life or someone else's may depend on it. It's not as if you can test the system by setting it off.
