Air bag light with no code 96 b2300
Femur808
My air bag light is on and is not showing a code. Once i turn the car on the air bag light stays on. I think it has to do with a connector not being plugged in.The wire is located behind the drivers seat. I removed the seat and found nothing to connect the wire to. Does anyone know where this wire is supposed to be plugged into? And does anyone even know what this wire is?
I can't help you; but, you might try re-posting your question in the general section. Many more folks read that section.
Hope someone jumps in to help you, Ed
Seatbelt sensor. It probably is the cause of the light.
