aftermarket gauges
TheDanger2801
Orono, ME/Yardley, PA
i want to install an oil pressure gauge in my 98. can some one tell me where and how to install the sender? also where should i tap for the gauge to get power?
Install the sender in a T fitting next to the original one and pull power for the gauge itself of the fuse panel. Get power for the lights of the illumination feed to either the radio or the instrument panel. Run the ground directly to a dash ground.
This is assuming that you are electric gauge.
