advice for removing the engine
how is that??
why would that be?
that is a depends. generally i add metal and strapping. this doubles the metal at those points and is much stronger at the fold out.
my core support is much stronger than stock....in all of my rigs. and removable. because they have to be....we roll them over for fun....and smash into trees and undercut rock banks going from challenge to challenge.
the inner panels are very weak regardless. it is just much cheaper to build them the way they are in time labor and money.
and i hit dozens of deer....though my layout is also conducive to that because actual core exposure is no where near stock.
If it's not reinforced properly when it's reinstalled the results won't be pretty.
Thanks for all your advice, I'm going to take my courage in both hands and crawl to detach the box, I'm bad at welding so I prefer not to remove the support. To lift the engine I have a chain hoist
Since I couldn't find an American 2.9, I changed it to a European 2.9 like in the attached photos. It's a little different but the block is the same. It's a little more complicated but not too much. I'll tell you how the engine is once it's finished.
I’d love to get my hands on one of those intakes…
Euro 2.9 but not Cosworth? Missed opportunity? LOL
No, I didn't miss the opportunity to install a Cosworth. I'm not a mechanic at all, and it would be too complicated for me to change the throttle cable, wiring, ECU, and probably other things. On this one, I had to reinstall my intake manifold to be able to reconnect everything to it.
Now I've almost finished putting everything back together, and I found the oil cooler gasket (an O-ring of about 2.5 inches) (the part where the vertical oil filter goes). Do you think it's possible to reinstall it from underneath so I don't have to take everything apart again?
I wasn't trying to be mean. Hence the LOL.
Looks good. Every project is subject to location. Gotta says it weird how many high HP builds come from California when they have arguably the most restrictive rules in the country.
So is that 2.5 Turbo Diesel related to teh cologne 2.9 in any way?
No, it's a VM 4-cylinder turbo diesel engine. Here in Europe, it was used in many car brands: Fiat, Land Rover, Jeep, even some Toyotas... and in the Ford Scorpio with the A4LD automatic transmission, hence the ease of conversion, if that were permitted.
Event Coverage
TRS Merch
