Adding factory power windows
BobSacamano
Brookhaven, MS
I have a 96 with manual windows. I’m considering adding factory power windows. I have found a donor truck. So my question is, do I need the GEM from the donor or can I add the wires to my GEM?
Here are the different listed GEM modules from the junkyard. I don't see power windows so they might all support that.
Memory, (seat, under driver seat)
Temperature, (evaporator case mounted)
Multifunction, (behind center dash), remote keyless entry, 4x2, ID F57B-14B205-AF
Multifunction, (behind center dash), remote keyless entry, 4x2, ID F57B-14B205-DG
Multifunction, (behind center dash), remote keyless entry, 4x2, ID F57B-14B205-DH
Multifunction, (behind center dash), remote keyless entry, 4x4, ID F57B-14B205-EL
ABS, 4 wheel ABS, (LH inner fender)
Cruise Control, (servo assembly, RH engine compartment)
Multifunction, (behind center dash), w/o remote keyless entry; ID F57B-14B205-AE
Multifunction, (behind center dash), w/o remote keyless entry; ID F67B-14B205-AB
Theft-Locking, keyless entry (LH cab corner), ID F57F-15604-EB
Theft-Locking, keyless entry (LH cab corner), ID F57F-15604-EC
Theft-Locking, keyless entry (LH cab corner), ID F57F-15604-JA
Theft-Locking, keyless entry (LH cab corner), ID F57F-15K602-AA
Theft-Locking, keyless entry (LH cab corner), ID F7CF-15604-EA
Theft-Locking, keyless entry (LH cab corner), ID F7CF-15604-FB
Multifunction, (behind center dash), remote keyless entry, 4x2, ID F67B-14B205-DA
Multifunction, (behind center dash), remote keyless entry, 4x4, ID F67B-14B205-EA
ABS, 2 wheel ABS, (center dash), ID F57F-2C018-AA
ABS, 2 wheel ABS, (center dash), w/o ID F57F-2C018-AA
Air Bag, (RH kick panel)
Lamps, (daytime running lamps, LH lower radiator support)
Here are some diagrams. Look way down the page for your year. Looks like there is only two connections for the GEM
