xentris02
i added a bottle of bar's leaks rear main seal repair in hopes to sop all of the leaks i in my motor, if not at least help them or slow them down. after i added it i noticed (while i was the truck while running) that the oil was making a splashing like noise. now if i look into the motor from the top with the hood open i cant hear it. but if i sit in the cab i can ever so slightly. now i did a finger check to see if the weights were the same and if they wernt they were darn close. and and it looks like actual oil with a slight bluish tint so any ideas? and i replaced the pvc valve at the same time .
