The high pressure service port is located on the A/C compressor to condenser discharge line. The low pressure service port is located in the evaporator to compressor suction line.
The system spec is 1.38 lbs of R134a refrigerant.
Belated thanks to my question,my son took it to a mechanic so I never got around to actually putting freon in his truck.the low side is port just behind and to the right of the coolant overflow tank and the wiper fluid tank is a black cylinder (about the size of an extra large oil filter)with two lines coming out of it ... There is also a smaller line (a few inches long sticking straight up) which seems as if the adapter from this can of refrigerant would fit onto.
the high side port will be in the line between the compressor and the condensor(in front of the radiator) it will look just like the low side port
