You have to shorten the crank bolt some likely but that's it.
The front and rear areas of the oil pan sealing surface are slightly different but switching to the newer front seal housing fixes that (and filling in the rear bearing cap like I mentioned...), there are a couple holes in the oil pan that will need to be enlarged to 8mm instead of 6mm but everything lines up. I'm assuming you were planning on using the aluminum pan. There's a chance you might need to use a newer oil pump on the older block to clear the oil pan, I did with the turbocoupe block and the Ranger oil pan, just used the Ranger oil pump...
There were some changes over the years near the distributor area, I've had to drill and tap the third hole for the power steering bracket... This hole goes through to the aux shaft area, the crank sensor holes you'll be drilling go into the crankcase as well so clean up after doing that...
That's all I can think of, just make a good and accurate template for the crank sensor, I used thin cardboard like beer box or cereal box, punched the one pin hole, pushed a pencil point (or center punch, pick your poison, just push hard enough to get a sharp indent from the block hole into the cardboard) hard into the outer front seal housing bolt holes so you get far out references for accuracy
