adapter?
jonsranger
Spartanburg, SC
does anybody still make an adapter to go from a t5 wc to a np205? I know advance adapters used to, but they don't anymore. i was going to do a divorce t-case but then my drive shaft would be super short, plus i don't want to have to get 2 different driveshafts made and buy some other little things like mounts and output shaft yokes twice.
I belive you can use a 4x4 s10 of the older vintage from behind a 4.3l they have t5's with 4x4 T case extensions. you would need to remove the t-case extension and use it on your T-5. im not postive on the T case configuration tho. but atlest you would have a 4x4 t case extension to work from and not a 2wd tailshaft. depending on the T case used you might only have to get a shaft or adappter plate made.
