Acts like the throttle's disconnected
wwracer
Island Park ID
Hey guys great site. Bought my third Ranger two years ago. Other than the crappy front hubs it's been a good truck. It has 160K on her uses no oil and gets great gas mileage. Today I started my truck and started as normal then stalled. After a few attempts I got it to idle but it "hunts" between 500 and 1000 RPM till warm then holds a normal idle. The real problem is when I push the gas pedal down the motor will not rev. I visually verified that the cable is attatched, I open the throttle and it just bogs and stalls. Any ideas? Signed stuck at my cabin 30 miles from town......
Throttle Posistion Sensor. TPS
It helps the computer know where the throttle is at. It's a 500% over ride sensor. The computer cannot get feedback from the O2 sensors fast enough to notice someone stepping on the pedal. It would cause a bogging situation. The TPS helps this by increasing the injector pulses right away, then leveling out later from O2 feedback. That's the simplest I can put it.
Ranger 44, that's where I was leaning toward also, however, just as a guess I pulled the plug on the MAF and she sprung back to life. Drove it a bit a seemed to run as well or better than it did when the MAF was working. I plugged it back in just to make sure and it crapped out as soon as I attatched the plug. I'll try cleaning the wires, but visually they already look pretty clean. I'm pretty sure the sensors dead, but at a 120.00 for a new one I'll give it a whirl
