swynx
So I've previously had a high idle problem. Ron was helping me with that but then I tore the front end down and installed a aussie so I haven't fiddled with the high idle. . Started it up, it has a squeel. When I let the clutch out without pushing the gas to see if it would move it idled down really low and stopped squeeling. Then rpms jumped to 3000 and it ran funny. Then ran high idle but not rough. When I shut it off it has a real distinct hissing sound.
I have replaced Tps iac both 02 pcv valve maf fuel pump fuel filter fuel pressure regulator ect sensor
Idk if it makes a difference. My buddy said it wouldn't matter but I thought it would. They didn't give me any gasket for the maf so I used red gasket maker.
It also seems to get worse with every new sensor I change. Fuel pump/fpr is what caused this. It never idled high before that. It was drive able before I changed maf and pcv
