first of all,the inboarded springs were on the front,and this thread is about rear flex.while those coils were removed the next week from when that pic was taken and replaced with a transverse leaf as in the rear,the point of the pic was to show that the tire on the droop side can still carry weight,something you don't see too often.while those pics don't show a huge amount of detail,this thread wasn't about putting up a whole bunch of pics of my truck.i have a whole thread for that.
Then don't post pictures of your front suspension, or your truck. Pretty simple
this is true...but what is also true is that if you want to 'achieve extreme rear flex' you won't get it from a system that holds the axle off the ground when getting crossed up.there seems to be a lot of confusion and disinformation on this site from people that think they know what might work,but have never built anything that actually achieves 'extreme flex'...on either end of the truck.
"extreme flex" is a relative term, and while I agree alot of "non extreme" suspension get put up in here, it is not up to you to decide the level.
a clarification of his goals is not really needed...he posted a thread titled 'achieving extreme rear flex' in the 'extreme suspensions' forum.
seems pretty clear to me.
seems pretty clear to me that you are obsessed with your monstrosity of a truck
now i agree completely with you that having one end of the truck flex more freely than the other is a bad idea.i went through all that when i was changing out the suspension on mine every week trying to get a good,balanced,safe to drive truck.but i'm not going to make assumptions about what the op has or knows about all that-i'm simply going to address his question.if he wants to know about an extreme flexing balanced system for his truck,i'd be happy to pitch in with my hard earned knowledge on the subject. .
you are welcome to pitch in your opinion, but you do more than just "pitch it in" you are coming off as forcing it, and its not a subject where your method is anywhere near accepted as the "best"
you've just demonstrated you know nothing about how my suspension system works.it has no more in common with a truck running floppy shackles than it does with baked lasagna.
might be time to do some studyin'
I think baked lasagna probably takes more skill to make, than your suspension. You had to be drunk when you built it... right?
i'm talking about real trucks here,not toys.
So are we, and you start posting pictures of your novelty item
consideration of cog is important,but what's even more important is it's relationship with insantaneous roll center.this is what's going to determine roll carachteristics of any suspension,from monster trucks to indy cars.my cog is fairly high,but i've placed my roll center just below it so there will be some transfer to the outside tire on cornering,but not so low that there is a tendency to roll in off cambered situations(which my truck handles just fine)
while this may not translate into the ultimate in cornering force,this was never an important design criteria.stability,on the other hand,was.
the truck is in the midst of a refit at the moment,but on completion i will post video of it in action.all sorts of action.
you may want to post video of a similarly capable truck of your construction to compare to it.
