I think he meant that a "dislocating" suspension setup (revolver shackles, uncaptured coils, etc.) will not convey near as much traction as a properly engineered setup that will also still allow the tire to reach the ground, the spring on which can still maintain some contact pressure of the tire against the ground.?
the problem with a leaf spring is that it can only put pressure on the axle to the point it reaches it's free amount of arch(the amount it would have laying on the floor,not attached to anything).once you go past this amount of arch in droop,the spring is no longer pushing down on the axle...the axle is actually pulling down the spring.so what's happenning is the spring is holding the axle up.
in slo-vo's pics above on the rock you can see that the left rear tire is about to leave the ground...it no longer has any weight on it.if the truck is driven up an obstacle any further,this wheel will be off the ground.at this point it is hanging from the leaf spring.if the u-bolts were removed from this side at this point,disconnecting the diff from the spring,the wheel would drop to the ground.not only drop,but would have a measureable amount of pressure on it from the other spring pressing down on the whole solid diff.
(you can see how this works by placing a board so it's ends are on two scales,then stand off towards one end of the board.there will be weight on both scales,but there will be more on the one you are closer to.the same thing happens with a live axle suspension that is supported only by the spring on one side...both wheels will have pressure on them,but there will be more on the side closest to the supporting spring.now,while standing on the board,get a friend to lift the far end of the board.no weight will be shown on the scale on that side,just as there is no weight on a tire when it's end of the axle is held aloft by an overextended leaf spring.)
since the spring is being used to locate the axle as well as support it,this would not be an ideal way to get underway of course...but if the axle were to be located by another means such as a 3 or 4 link and the springs simply used to support the vehicle then the wheel could be allowed to drop,still have pressure on it,and drive the vehicle.
a semi-eliptical leaf spring with the axle bolted to it for location can never achieve extreme droop and still be a driveable vehicle because the two functions of locating and supporting are inherantly working against each other.improve one,the other will suffer.
for droop,the optimum leaf spring will be a very soft one with huge arch and a very long shackle to take up the huge length changes caused by this large arch needing to flatten out and arch.
for location the optimum spring will be as flat as possible(even with a slight negative arch so the axle center is in line with the spring eyes)and very stiff,with a very short shackle.
to balance these two factors you must compromise somewhere.
A truck with short, stiff uncaptured springs is not gonna work well, period.
exactly...uncaptured indicates the location function has been comprimised.this was the problem i had when i tried the drop links.
