- Aug 18, 2007
- Va
- 1990 Bronco II
OK, My Bronco II runs so good right now & I really don't want to do anything to it that might cause me any problems. If it ain't broke, don't fix it is usually my motto. I'll just go with the tires & see what happens from there.
Just for information purposes. I have installed '94 Explorer front & rear springs because my rear springs were sagging badly. Once I installed the rear springs, my front end was lower then the rear so I changed out the front & now it is sitting level. I measured off the pavement to the center of the wheel well & I am sitting at 31 3/4" give or take all the way around now.
I was given a set of 265/75R/15 tires & wheels off of an Explorer & I used them for about a month with no rubbing anywhere. Keep in mind I was not doing any off road driving. I was worried tires that large would cause me problems with the transmission so I decided to take them off & installed 215/75R/15 tires. I didn't keep a check on the gas mileage with the 16" tires that I was using so I have no idea what I was getting as gas wasn't that big a concern at the time.
I've checked out the calculators on TRS & have a good idea as to how the 16" tires will effect my speedometer, but I have no idea how they would effect gas consumption. What do you think about using the 16" instead of the 235s? I have a good selection of tires to choose from but trying to save myself some work & time if possible.
